Are you looking for Casablanca CSA-54036 - 5-Blade 52 Ceiling Fan with Dark Walnut Blades? We found best price for you. Go to link below to buy the Casablanca CSA-54036 - 5-Blade 52 Ceiling Fan with Dark Walnut Blades for the lowest price.
Casablanca CSA-54036 - 5-Blade 52 Ceiling Fan with Dark Walnut Blades Review
I own some ceiling fans, but Casablanca CSA-54036 - 5-Blade 52 Ceiling Fan with Dark Walnut Blades is my most favourite.
Casablanca CSA-54036 - 5-Blade 52 Ceiling Fan with Dark Walnut Blades Description
Casablanca 5-Blade 52 Ceiling Fan with Dark Walnut BladesIncludes 3 and 2 DownrodsNew blade hole pattern, ABS All-Weather - IncludedBlade Pitch: 134-Speed Pullchain172mm x 20mm Direct Drive MotorHigh Speed RPM: 217 (6423.91 CFM Airflow) Airflow efficiency at high speed: 79.21 CFM/WattOptional Accessory Control: 99019 Universal 4-Speed Handheld Remote & Reciever:
Related posts
- Casablanca CSA-54020 - 5-Blade 54 Ceiling Fan with Dark Walnut/Distressed Walnut Blades
- Casablanca CSA-53195 - 5-Blade 44 Ceiling Fan with Distressed Walnut/Dark Walnut Blades
- Casablanca CSA-59518 - 5-Blade 66 Ceiling Fan with Distressed Walnut/Dark Walnut Blades
- Casablanca CSA-54006 - 5-Blade 54 Ceiling Fan with Distressed Walnut/Dark Walnut Blades
- Casablanca CSA-54031 - 5-Blade 54 Ceiling Fan with Smoked Walnut/Dark Walnut Blades
- Casablanca CSA-55006 - 5-Blade 60 Ceiling Fan with Distressed Walnut/Dark Walnut Blades
- Casablanca CSA-59524 - 5-Blade 31 Ceiling Fan with Dark Walnut Blades
- Casablanca CSA-59060 - 5-Blade 54 Ceiling Fan with Dark Walnut Blades
- Casablanca CSA-59090 - 5-Blade 54 Ceiling Fan with Dark Walnut Blades
- Casablanca CSA-66083 - 3-Blade 30 Ceiling Fan with Candelier Dark Walnut Blades
- Casablanca CSA-54023 - 5-Blade 54 Ceiling Fan with Burnt Walnut/Walnut Blades
- Casablanca CSA-53187 - 5-Blade 44 Ceiling Fan with Walnut/Burnt Walnut Blades
- Casablanca CSA-54042 - 5-Blade 52 Ceiling Fan with Walnut/Burnt Walnut Blades
- Casablanca CSA-59069 - 4-Blade 54 Ceiling Fan with Walnut/Burnt Walnut Blades
- Casablanca CSA-59068 - 4-Blade 54 Ceiling Fan with Walnut/Burnt Walnut Blades
- Casablanca CSA-54021 - 5-Blade 54 Ceiling Fan with Walnut/Burnt Walnut Blades
