Back to blog
Solas 4-Blade Propeller, Pressed Rubber Hub / Aluminum, 13 dia x 15 pitch, RH
Credits to Overton's
Are you looking for Solas 4-Blade Propeller, Pressed Rubber Hub / Aluminum, 13 dia x 15 pitch, RH? We found best price for you. Go to link below to buy the Solas 4-Blade Propeller, Pressed Rubber Hub / Aluminum, 13 dia x 15 pitch, RH for the lowest price.
Solas 4-Blade Propeller, Pressed Rubber Hub / Aluminum, 13 dia x 15 pitch, RH Review
I red all reviews of Solas 4-Blade Propeller, Pressed Rubber Hub / Aluminum, 13 dia x 15 pitch, RH, before my purchase and all were positive!
Solas 4-Blade Propeller, Pressed Rubber Hub / Aluminum, 13 dia x 15 pitch, RH Description
Engineered to meet the needs of performance-driven boaters, Solas propellers deliver peak characteristics to a wide range of applications. Solas Aluminum Props are squeeze-casted to make them stronger and easier to repair than any other prop. Pressed rubber hub provides for long-lasting consistency. Suzuki/Johnson ApplicationsDF 90 (4 stroke) 01 thruDF 115 (4 stroke) 01 thruDF 140 (4 stroke) 01 thru15 splineYamaha ApplicationsF75 (4 stroke) 03 thruF80 (4 stroke) 99 thruF90 (4 stroke) 03 thruF100 (4 stroke) 99 thruF115 (4 stroke) 00 thruT50 (4 stroke) 96 thruT60 (4 stroke) 03 thruthru hub exhaust
